Jerryjerry05
Outstanding Contributor
2003 Yam 200TXRB About 300 hrs.
Motor starts and runs fine.
No water from pee tube, even if taken loose at the rectifier.
Tried weed eater string up in the rectifier and nothing.
Should I try taking the rectifier apart?
Owner says the impeller was changed last year???
Would this make the cylinders overheat? Temp was high on the center cyl. 190d. 150-60 on the others.
THANKS!!
THANKS!!
