While I have the floor over the engines off (to work on the port engine) I took a look at an annoying oil leak on the starboard side. It leaks a quart every week or so into the bilge. Doesn't matter if the engine is running or sitting. I cleaned the bilge and put down absorbent material so I could be sure where it was. By standing on my head in front of the engine I easily located the issue. It is the dip stick tube.
On this engine (2002 350) there are two dip stick tubes (one on each side). They don't actually go into the pan, but go into a T fitting that hangs below the pan on the bottom of the engine. The inboard tube (the one most convenient to check the oil) is dripping. I can barely reach under, but where the tube bends to go under the engine it feels rough, as if corroded. And that is where the leak is. It runs around the curve a little ways and then drips off well before reaching the T.
The obvious "correct fix" would be to pull the engine and replace (or maybe weld) the tube (or in my case remove it and block it off, as parts are not available, I could then check the oil from the other tube).
But "pull the engine"" is the expensive part. I have toyed with the idea of sticking something down that tube to block off the leak from the inside and then using the other side, but I am not sure how well that might work. I hate to pull the engine if some rags and a coat hanger might eliminate the leak or get it to a manageable level.
Comments? Ideas?
CaboJohn
Comments? Ideas?
CaboJohn
