Tylerfromig
I have a 2005 Mercury Optimax 225 and I’m trying to track down an oil system issue.
The small engine-mounted reserve oil tank slowly drains while the motor sits, even when the main onboard oil tank is full. The motor sat about 7 months recently and the reserve tank completely emptied.
Before that, I noticed the level would slowly drop over time while sitting. If I take the reserve tank cap off and refill/purge it, the system fills back up and seems normal again.
From what I understand, the reserve tank should stay full because the remote tank feeds it continuously, so I’m assuming I either have:
* a bad check valve,
* an air leak in the oil line,
* or possibly a bad cap/o-ring on the engine tank.
My main question is:
Where is the check valve usually located on these 2005 225 Optimax motors? Is it typically near the engine-mounted tank under the cowling or back near the remote tank in the boat?
Also, has anyone had similar symptoms where the reserve tank drains only while sitting?
