PCV Valve Question
sab
I'm going through my newly acquired 2004 350 Mag MPI, and on my list is replacing the Positive Crankcase Ventilation (PCV) valve. The one I removed from the engine is 100% plastic and you can stick your little finger almost right through it. (The vent tube is a corrugated like the ones you protected wire runs with) The PCV valve I got from mercury (P/N #21-8M2017060) has a metal base with a check valve in it, and a different diameter vent hose. I'm assume the mercury one is the correct part that should be installed (need a new vent hose). I'm not looking for problems. Maybe they had problems so they installed the hollow PCV? Comments?
marine engines run at high power settings and there is very little vac to pull the blowby out of the engine .
To keep the fumes in check the hose it just directed at the flame arrestor
I installed what I believe to be stock OEM PVC and new (fuel type) vent.
Next issue - I can't get get the oil filter off. I replaced over 300 filters in over 30 years. Bent the handle of my oil wrench and starting to crease wall of the filter with 3 foot persuader/pipe on on the wrench. Afraid I going to snap mount/fixture if I force it. Hopefully engine starts today and will try again with hot engine/oil. It a Purolator - I wonder if its the right type or it was leaking
If this is a remote oil filter that happens a lot.You will need to use heat where the rubber gasket is then use the wrench
If you cant get it off in a normal manner then you will have to destroy it and get it off the best way you can.........Been there and done that a few times.
Some even from the factory!!
Jack- thanks I need to get it the engine started and the oil/gasket hot before try again, first, before I drive a screw driver through it. Worse come to worst I'll let the Northshore repair shop do it - I will snap the whole assembly it If I try with the persuader and it is remote as BTDoctor commented
Driving a screw driver thru it not terribly effective as the very thin sheet metal will tear. The one and only time I had this happen on my boat I had to end up using a chisel to drive the base plate of the filter with a hammer, which is the strongest metal on the filter. Now... I always "lube" the rubber on both oil and fuel filters with a very thin film of oil and make sure that the mating surface of the filter is clean and free from crap and any burrs.
