I read that one should use Permatex Aviation (Form -a-Gasket #3, in the brush can) for sealing the threads on the fuel filter water separator head. I applied it to the male and female threads on a 3/8" stainless steel fuel shutoff valve and 3/8 NPT male x 3/8" barb fitting and followed the instructions, letting it set for 20 minutes (it says a few minutes) then assembled everything tight and it leaks like a sieve. I wondered about the Permatex Aviation #3 as I can clean it off with alcohol and gasoline has alcohol in it. The gasoline came right through the threads.
What gives with that, as all over the internet everyone says to use Permatex Aviation?
I think I'm going to try the yellow Teflon tape, since the valve comes before the fuel filter. I read to use the yellow Teflon tape and not to put any on the first threads. Since it is going before the filter if any Teflon bits get past the threads, the fuel filter will pick it up.
What about this product, it says it is specifically for E10 and E85 fuels:
Premium pipe thread sealant with PTFE. Provides a positive seal on pipe thread, joints, fittings, hoses, nozzles, LPG cylinders, pump assemblies, motors, oil burners, hydraulics, compressors, engines, housings, plugs, fuel lines, couplings and more. Excellent resistance to gasoline, up to 20 percent alcohol and petroleum blends, petroleum solvents, kerosene, diesel oil, propane, butane, LPG, cutting oils, ammonia, aliphatic solvents, acids, steam, potable water, compressed air and more.
