Peter Cameron
Clipper 34 with ford lehman diesel
i have a VDO fuel guage and sender, the sender is faulty and dimensions are 830mm in length 55 mm diameter (sender Tube),
vdo say this spec is no longer available and the replacement is shorter and smaller diameter requiring a ring to fill the hole in the tank and take the new sender , even if i go to a Wema sender this will also require a new guage and sender which will also be of a smaller spec also requiring a ring, does anyone know of a way around this problem? i believe the old sender cannot be repaired.
regards
Peter C
regards
Peter C
