I'll give details as best as I can. This is what it does, it being a 99 mercruiser 5.0 alpha 2bbl carb model. Pops and bangs at 2000 rpms (under load) and won't accelerate higher due to this. Idle is great, smooth acceleration up to 1900. Under no load it will rev fine all the way up if throttle is pushed moderate or slow, if pushed fast it will pop briefly. This is what has been done so far.
dist cap and rotor replaiced
coil replaced
plugs replaced
fuel pump replaced (electric)
ign sensor under dist cap replaced
noticed neither old or new fuel pump will fill empty fuel filter/water seperator, ran fuel direct to carb and gets fuel but same issue as above.
Stumped now, thanks in advance for any help
coil replaced
plugs replaced
