swampyankee
I've been working the bugs out of the 318s in our 78 Silverton 31. Mostly working past cooling issues. Just when it seemed I might have a good season, what looks like major problems have surfaced on the port engine.
Background is, boat had not been used much in recent years and had been maintained on a shoestring. Records show that the last major work was done around 2007 or so, with only about 250 hours accumulated since.
My first issue with the port engine goes back to fall of '18 when we were taking rev./speed readings up and down the river. Although we were able to rev to 3500 or so, on the last run it wouldn't go past 2500 rpm and was bogging. At the time I thought it might need a good carb cleaning/rebuild. The boat didn't go in the water in '19 as I did some work on it including new manifolds and riders.
We launched a couple weeks ago and have used it a few times since. The port engine has always used more oil than the starboard, and I topped it off with maybe a 1/2 quart before we left the dock. About a 1/2 hour out I noticed the port engine starting to lose power so we turned around. Oil pressure was steady at 40 psi and temp was at 120 f the whole time, but I noticed it getting a lot of blowby under load. When we returned I found a fair mount of oil which appears to have pumped out of the dipstick tube
and there was alot of oil in the spark arrestor where the breather tube was attached. Starting it back up there was some oil smoke coming out of the breather., although there was no evidence of oil burning out the exhaust, not oil sheen on the water.
I will do a compression test to check for bad rings. If so, that engine is toast, along with our boating season. But would there be a simpler and less costly reason for this to happen?
