Ok I have a 1986 crest 25 foot pontoon, New to me. 50 HP evinrude ( 86 also) (e50belcde) Got the motor running great and it pushes the boat along at a pretty good clip, However, I noticed that the motor doesnt set down on the transom all the way. it is bolted to it but the lip that would rest on the top of the transom is off about 2 inches. I can see where someone who had it before me had drilled new holes to put the motor in the current position.. My problem I noticed today when I took it out is that it has real bad cavatation at WOT going straight. I figure it is where the motor is raised, but upon further inspection I can see that the motor skeg would be touching the ground if I lowered the transom plate. I am gonna replace the transom anyway as it appears to be starting to rot. Do you think by lowering the plate back down will fix the cavitation? would a hydro fin help any. Im just not sure what to do about this.. While just sitting in the water the cavatation plate is about 4-5 inches under the water level but at WOT I can see the cav. Plate. Thanks.
