justin12747
My 1990 force 120 prop does not spin left or right while in neutral. It will spin freely either direction while in forward or reverse. Is this normal?
No I didnt. But I probably rotated the shift rod somehow. I've put it on and taken it off at least 5 times now. I've got the service manual and it says to thread the shift rod in until it bottoms out, then back it off 4 turns. I will try that and see what happens.No, not normal.
You didn't remove the shift pin on the side of the gear box?
The linkage is messed up somehow.
