Question about Chrysler marine 318 distributor rotor
MoparJoe
Recently at a swap meet I picked up a box labelled as 318 marine parts, it included a rotor that had a wider contact at the spark-end than I'm used to seeing. Here's a pic:
I understand that marine engines sometimes or mostly have the crank turning the opposite way vs how they turn in a car. But I'm wondering about that wide contact - can someone tell me the theory behind it? Does the marine 318 operate over a wider spark advance curve - and hence would need the wider contact to insure the spark can jump from rotor to post? I thought it would be cool to put that rotor in my car (I have small block 318) but the shaft end design is totally different, it won't fit. But my primary question is - what is the theory behind the wider contact ?
You might pose your rotor question to a very knowledgeable group of Mopar enthusiasts here......
https://www.forabodiesonly.com/mopar/forums/electrical-and-ignition.54/
.....or in the Chrysler I/O section on this site.
I'm a member of FABO but if nobody on this board can answer a question about the Sierra marine rotor and it's design then the odds of getting an answer on FABO are less than zero. I sure wish I could drop that rotor in my distributor. I'm not sure what the Chrysler I/O section is, I'll see if I can find it after I post this.
