Hi guys just got done servicing my older 60 that was sitting in my collection gathering dust. did the carbs, had no spark and DVA test results had me put in a new stator. Runs perfect BUT i'm not happy with the bottom fuel bowl part # 344271. It weeps fuel , even with new gaskets. Also, it wasnt sitting flush with the body like the top carb. It really had to be screwed in tight to get it to seal at all. Not good! I tried to see if it was hanging up anywhere, but no luck. Didn't think to check if it was warped. Does this sound normal? can you sand them down ? how can aluminum warp anyway?
Also, the only difference between this year and the more powerful 1984 version that i can find are the high speed orifices. Mine has the 55d's and the 84's had 56d's. Can I remove the airbox and go up to the 56d for more power?
