Going to try and be short and concise as possible to avoid rambling, as I am feeling really defeated. Tilt motor was working half the time, figured relays were sticking/bad, so now trying to replace relay but only getting 2.5V when when activating switch up or down at pin 30 on both relays. This should be 12V correct? Is something wrong with my wiring? I do understand that I need an inline fuse on the 12V wire going to the switch.
I attached the wiring diagram and pins that I used. I know the wiring is really bad/messy right now, I was trying to get it functioning correctly, then clean it up afterwards.
I attached some pictures with some labels, but i do understand if it is really hard to see what is going on so just let me know if I am missing any other information that would need to be included.
https://imgur.com/a/HSbCLRf
Using the same setup below on both relays with different switch/motor wires obviously:
positive to motor: 30
positive battery 12V: 87
negative battery: 87a
negative battery: 85
from switch: 86
positive battery 12V: to switch red wire
I would really appreciate any help.
from switch: 86
