1975 Johnson 6 hp.
I have to pull the starter rope out quickly to have the pinion gear travel up the spool to engage the flywheel. If I pull at a slower rate the pinion gear will stay at the bottom position. I have four other 6 hp Johnson motors of varied years. The slightest slowest pull of the starter rope the pinion gear will start its climb of the spool for the flywheel on them all.. The roll pin is in place so is the clip spring that hugs onto the spool. The guides for the roll pin are smooth and unobstructed. All parts are clean and in position.. I am puzzled
at this point.
Any thoughts or suggestions on this matter.
