replace pull start spring on 2HP, 1984 Johnson
wmpaul47
Pull start on this model is attached to the engine cover by a single bolt, the spring looks like it must be installed on the pull rope spool then mounted to the housing. Problem is the spool is very difficult to coil the spring and try to get it mounted properly. Any tips?
If memory serves me right.... Have the spring end connected to the pulley leaving the rest of the spring hanging outside and in the slot in the housing. Secure the pulley to the housing.
Now, crank/turn the pulley with your hand so as to pull the spring into place.
Continue cranking the pulley until it's completely wound.
Holding the pulley from unwinding... Insert the cord into the retaining hole and out the hole in the housing.
HINT: Some of us have the cord already wound on the pulley with the handle end sort of folded over so it stays put until the final stage whereas we could flip the end out with a scribe, screwdriver, something.
Use caution so as not to lose your grip in the pulley or the cord... you do not want that pulley to freely unwind until you're ready!
