Thanks for the response. What does this do?Sending unit for trim gage at the helm.
Got it! Thanks for your helpIt senses the trim position of the engine (the angle) and would feed that trim position to an analog or digital gage to allow you to visually adjust the engine trim to optimze the boat ride quality or speed based on load or other factors.
Great! Thanks againThe most difficult part of that whole job is getting the lower cross pin out usually stuck, sometimes needs heat and a brass drift and a sledge hammer to knock it out, rememder to drive out the headed cross pins before driving out the two big pins. Disconnect the wiring and your out. I've had good success with Arco trim motors, make sure you get the correct motor with either the 2 wire or 3 wire trim motor. Good luck.
I managed to get the pin out, but I cannot seem to get the bolt out. The video says to just tap it out, but this looks like a screw.
I was wondering why my trim harness had two disconnected brown/white stripe wires on my new-to-me Mercury outboard, and now I know! From the Mercury service manual, the green and blue go to the remote trim switch, but they don't show any connections for the brown/white stripe wires, so I found your video as I thought it might be related to a trim gauge. Thank you for this, I can now stop stressing about why those two wires are disconnected. I was worried the previous owner had disabled an alarm or something.Watch this video:
I was wondering why my trim harness had two disconnected brown/white stripe wires on my new-to-me Mercury outboard, and now I know! From the Mercury service manual, the green and blue go to the remote trim switch, but they don't show any connections for the brown/white stripe wires, so I found your video as I thought it might be related to a trim gauge. Thank you for this, I can now stop stressing about why those two wires are disconnected. I was worried the previous owner had disabled an alarm or something.I was running out of time to complete my dissertation, so I turned to https://academized.com/dissertation-writing-service for assistance. The service was exceptional. The writer assigned to my project was knowledgeable and provided a well-researched and well-structured dissertation. They followed my instructions carefully and even provided additional insights that improved my work. The communication was excellent, and the final product was delivered on time. I’m very satisfied with the quality of the work and would highly recommend this service to anyone needing help with their dissertation.
