School Shop Teacher needs help
Stargard
Hi Guys, I teach a secondary school shop class and we picked up a (01/24/1989 70Hp) Mercury yesterday and wanted to order service/owners manual but cannot find it on the mercury site. The paperwork and the dealers MercNET site shows serial # 0A748383 and M# 10704129C. But why is it not searchable on mercury's site for parts or manuals? The serial number on the motor is not readable, just too old and faded, the plug says A748383. Any help is appreciated. The dealer is gone on vacation so I cannot get him for a month.
Serial number should be stamped on a welch plug on the engine (won't fade out) Is this a large bore 3 cylinder 70 r the 3 cylinder 2 carb model? If it's the large bore the manual would be 90-13645-21095. If it is the small bore it would be 90-86135-51-593. This is according to a service manual index. Hope this helps.
Thank you so much for your info as we still have not found the manuals. It is a 3 cylinder 3. Carb motor. The welch plug has A748383 on it. Thats all for numbers other than what was posted. We appreciate any info that can shine some light onto this as we try to do everything “by the book” ... if we can findone!
Serial Number A748383 is coming up as an MERCURY CANADA 70 ELPTO Model Number 10704129C
70-H.P 1989 ELPTO US Serial Number Range C100000 - UP / CANADA START SERIAL # A742531 = 1989... <No question on the year model in my findings.
E = ELECTRIC START
L = LONG SHAFT (20")
PT = POWER TRIM
O = OIL INJECTION
Since your Model number 10704129C isn't coming up to help ensure a correct parts guide I was able to locate 3 others that are close enough that will work for your part searches all from the 1989 year models... If you search online the 3 model numbers below you'll find a few options to choose from...One is linked as an example.
70 [ELPTO]
10704129D https://www.crowleymarine.com/mercury-outboard/365.cfm?mdl=TEIKSF
1070412GC
1070412GD
OEM Service Manual part number 90-13645--2 covers engine models,
70/75/75 Marathon/75XD/75 Sea Pro 80/90 (3 Cylinder) 1987 thru 1993 AND 100 & 115 (4 Cylinder) 1988 thru 1993
(U) 0A997142 thru 0D283221 (B) 09502135 thru 09793576 (C) 0A722297 and Above
(U) 0B209468 thru 0D283221 (B) 09523034 thru 09793576 (C) 0A731673 and Above
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=90-13645--2&_sacat=0
E = ELECTRIC START
PT = POWER TRIM
O = OIL INJECTION
70 [ELPTO]
1070412GC
1070412GD
On behalf of our shop class, thank you so much for your insight and assistance in securing more detailed information as well as access to the manuals. We have started training the next generation of marine techs.
Best,
Martin
If you want to save a few more bucks here I have the manual (merc factory manual) for that motor in pdf form. If you drop me an email at [email protected] I can send it to you in a few emails (it's broken down into 7 chapters and some sub-chapter pdf files so the overall manual is fairly large so mails easier in smaller chunks).
This is an amazing offer...thank you. We did not get any budget for our marine program, so I have been financing it from my pocket for the students. They are very motivated and anxious to get started so after a few "step by step" lecture periods with your manual, the "marine team" will get busy! My email is on the way.
Best,
Martin
Make sure it the correct manual as it needs to be 90-13645-2 as this is a looper not a crossflow. If you need correct one PM me your email. Where are you located???
That's the manual I made available to him.
Hi Fazbullet,
Thank you for your message, very kind of you to reply. Indeed the manual that Graham sent to us is 90-13645-2
Best,
Martin
Thanks for the information!
Best,
Martin
Zcep, your piece "Raiding" is truly captivating! Your narrative style effortlessly draws readers into the world you've created. The vivid imagery and dynamic characters make it an engaging read from start to finish. Your mastery of storytelling shines through, creating an immersive experience. Moreover, I appreciate the meticulous attention to detail and the way you seamlessly weave emotions into the narrative. Your commitment to the craft is evident. By the way, I recently came across a fantastic resource on chicago style format at https://essaypro.com/blog/chicago-style-format. It might be handy for your future works. Keep up the excellent writing!
I agree with you, the information was helpful
