Setting Timing on a 75hp 4 cylinder
leachy
Hi All,
I think I know the answer to this but not 100% certain. Does the motor have to be in the water to set the timing. I know it needs to be in the water to set the idle.
Thanks in advance.
Leachy
Well generally I think the motor would start unless you have the fuel and or spark plugs out. It also needs the spark to trigger the timing light.
Yes, you must do those things first. No fuel, I usually take the plugs out for a lot of things. Never have done the procedure for timing, running or not.
