cnewton700
I have a 1984 Mercruiser 5.7L 260hp V8. The Rochester quadrajet (17090210) that had run for years on it finally needed replacing. I purchased a re-build that was advertised as being a replacement that was built and calibrated for the Rochester Quad 17090210. Felt great, then I noticed seller advertised as being built and calibrated for the Mercruiser 350 Magnum engine as well. I don't have a Magnum. The carb arrived and looked almost identical, intalled easily and it started right up but it ran terrible, rough, jerky and I had to use the throttle to keep it going between 1600 and 2000rpm. It wouldn't run on it's own or smooth out so I shut it down. It seems to me the jets, settings or something would have to be different for the higher HP Magnum engine than the standard or is there something I need to do or adjust or ...
