Hi all, I have purchased a 14ft starcraft that doesn't really handle well; I'm sure it's a setup issue, I just don't know how to correct it so i'm looking for some guidance.
Cruising between about 15 and 20 it's ok, but it starts to stuff the bow, anything over 25 is scary, I brought it up to 32 one time and it was terrifying.
What happens is the boat starts to plunge the bow into the water really hard, if I trim the motor up one notch it's better but then it does a prop stand trying to get on a plane.
It also doesn't like to turn at any speed, the engine just ventilates, but I'm guessing these two things are related.
The ventilation plate was about 3/4" below the bottom of the boat so I raised the engine a bit by placing a 3/4" piece of wood on the top of the transom. This seemed to help a little bit, but this boat still doesn't handle like all other aluminum boats I've used.
My prop is a little bit chewed up, I should probably replace or repair it, but I'd be surprised if that's causing this whole issue.
(yes i know painters tape isn't legal rego numbers...)
