Douglas112
Hi everyone. Trying to run compression test on this old 9.5, but when I screw the tester in,the engine doesn't want to spin.Actually striped the nut holding flywheel. Remove the tester and engine spins over blowing what seems like good air from plug holes pretty sure I'm using the right fitting on tester,and not screwing in to far. Engine's been stored for years and looks good for it's age. I removed plugs and sprayed wd40 in the cylinders and spun it over some with my impact gun. Then repeated several times hoping to get inside parts some lubrication.any idea's would be appreciated. I've been collecting new tune up and carb kits knowing everything would need re building or replacing. Then, it dawned on me to check compression before I spent any more money on seals and impellers etc.
