Silver(ton)Surfer
Hi,
Our new to us 1988 Silverton 40 Aft Cabin is equipped with twin, carbureted Crusader 350 engines.
After sitting for a while, it develops a strong crankcase smell in the cabin. What I mean by that is the typical smell that you get when you open the oil filler of a hot engine, which consists of blow-by and hot oil.
We believe that part of it is now actually coming from the carpet and the furniture as this issue has probably already been going on for some time.
When I’m sniffing around the engine room, everything seems pretty much dry and I struggle to locate any specific source for it. In fact, the only area where I am noticing the same small is at the flame arrestor, where the crank case vents end. I am also noticing a distinct gasoline smell in this area.
I guess some of it is normal for an old boat with carburated engines. Still, I have a few question, which I hope somebody will be able to answer:
- What is a good way to clean the eninge without polluting the environment? I am aware that there are dedicated cleaners but would you hose the engines down and can I avoid that the nasty water / oil / cleaner mix gets in the water?
- What about the strong odor that seems to originate for the carbs and the crankcase vents? Is this normal? Is there something I can do about it?
- When you get back to your boat after a few weeks, does it also have a very strong odor of hot oil / combustion byproducts in the cabin?
Oliver
Oliver
