I have a 40ft houseboat with a 1992 volvo penta 230B equipped with the SPC outboard. Boat had been in the water for 10 years and i took it out because it wouldnt' shift into gear. As it turns out, my list of outboard problems are as follows:
1 - Prop was missing! No wonder it wouldn't move forward
2 - cover that covers the linkages is missing. No wonder it is all gummed up.
3 - prior to prop falling off, it would shift FORWARD but wouldn't lock into REVERSE. I figured it was a hydraulic issue.
So the question is this: What are my options for outboards? It has an SPC on it but i'm wondering if this is something i should junk or just rebuild. Or are there other outdrive options i can mate with this motor? Or would it be easier/cheaper to just swap the entire set-up for something else? I'd love to have a bigger motor in this boat so i'm not against a motor swap. But I have no idea what would mate up. The 230B is running great so it would be a waste to junk it.
Thoughts?
And where should i look to get the SPC rebuilt if that is an option?
Joseph
Thoughts?
Joseph
