Boat is a 1991 Prowler 26' cruiser with a single 200hp TAMD 41B, Volvo Penta 260DP drive. Total of 850 hours on the boat from new.
Scenario:
- boat was running great 3 weeks ago when last used. Cruised easily at 20 kts @ 3450 RPM.
- Today, started fine, ran smooth.
- Took on fuel, headed out and throttled up.
- Engine running smooth, no vibration, but huge amounts of black sooty smoke from exhaust, and a thick trail of oily sludge floating in our wake. Due to the volume of smoke, my wife thought we were on fire.
- Smoke and sludge disappeared at lower throttle settings, but re-appeared again if throttle (& RPM) increased
- Unable to exceed 2500 RPM, so no turbo spooling.
- Considered lack of air, so removed filthy air filter (which was not, apparently, replaced at last service, although I paid for it)
- No improvement on removal of air filter
History -
- Fuel pump removed & fitted with all new parts approximately 4 years ago (probably 40 hours of running time ago), due to poor servicing (at fuel filter replacement, mechanic put Racor filter together upside down - seawater, previously filtered out of fuel, sucked into pump). Boat returned to us with new (not required - only 2 hours on existing new clutch) cone clutch, improperly installed, jammed in gear. *Three months to complete repairs.*
- Leg completely rebuilt 15 hours ago (new shafts, seals, gears, bellows, u-joints, clutch, etc. - only the housing re-used - due to sudden seal failure, allowing all gear oil to be pumped into the sea), plus new inner transom plate & exhaust. Again, due to poor service, boat was returned to us without shifting capability (shift cable jammed & kinked during engine removal/replacement). Another *three months to complete repairs*
At this point, I have no idea what could be causing my current problem. Unfortunately, the ONLY Volvo Penta service center around is the one that's done the poor service recently (in the last 3 years, I've spent about $15,000 in repairs there, with only 15 hours running time before another major problem).
I REALLY need to have a good idea what might be wrong before I have it taken back there again, as I need to search for another mechanic (any mechanic), and need to have some idea what is wrong!!
HELP!! Please!!
Scenario:
History -
HELP!! Please!!
