Throttle cam sleeve
Maj92az
My 92 48 spl
She runs good at speed but unreliable at idle and starring. You should see me at the dock lol
Waiting on carb kits and before I start fresh I noticed my two cam sleeves are missing. Probably an 8th inch or more of play in either direction...these damn tiny straw parts are pricey. With shipping I can not locate one for under $40.
Sounds dumb..but has anyone fabricated one? It's just a straw that slides over a stud- or got any ideas....
Also..side note..what is the spec on initial carb idle mixture screw setting... 1 1/2 turns out?
Thx
Yes. I located some poly tubing. Exact dead on size. Cost me $.22 a foot. Really only used .03 worth. And imagine...someone makes $15 off of a .03 part....
I did check, the tubing is rated at 200f and even if every year I replace it...i have 15 years worth lol
Maj92az-----I would say that you have no concept of what spare parts costs a manufacturer ---Consider the cost of a ware house and shelving / retrieval / computers / employees / packaging / shipping / profit etc.----This why on some online stores the cost of a part is $5.00 and shipping is $13.00.-------I do not believe they actually " make $15.00 " on that .03 cent part.
Yes. I located some poly tubing.​
You have to be careful on this tubing/rubber hose fixes as the fuel vapors can make em swell and cause binding in enclosed cams. I have a buddy that worked for MarFab that makes em out of black nylon rod ..
As you can tell i put no actual thought in my post about making $15 off of something
You know what I meant and was in a humorous fashion.. and it would surprise you or disappoint you if you knew my line of work...i am well aware of the costs to accomplish a manufactured part....anyways sorry to offend.....
And unless I am mistaken I researched poly tubing has a high resistance to gasoline and other petroulm products...
Yeah..anyways. back to boats...
I was double checking the material I used, - the polyethylene tubing. It crossed my mind that it is the same plastic used to make the plastic gas cans/tanks. Thanks for the advice. I had to double check for sure. Some material sure will breakdown or swell.
