Wow! lots of good info here! I leafed through past posts and found out about everything I need to do...and confirmed everything I've done thus far. I do run the gas out every time but with idle and running problems after sitting 2 months, this is what I've done so far...replaced fuel filter, replaced plugs, took out carb and soaked it 10 hours, cleaned gas can and fuel line, got new fuel with STA-BIL added, and changed oil. whew! I see that I need to drain a little oil out to bring it to optimum level, soak my parts again and hit it with compresses air when I remove it, add a little techron injector cleaner to the gas, and I may change to a better gas stabilizer. All I'm missing is a new carb kit, but everything looks good in there. When I originally opened the carb there was a orange granular substance, which i assumed was gas varnish. I want to avoid adjusting things that I am not qualified to adjust but if this last effort does not work I will take her in to the dealer.
So, first question, what is the best gas stabilizer to use?
Second question, I bought this new one year ago. If I have to take it in, what will I have to pay? just labor, or does the warranty cover everything?
I think that's all the questions I have. Please feel free to ask about any of these steps I've taken or make suggestions as you see needed. Thanks!
Munozafa
Munozafa
