MFS3.5A No 003-11085-0 Serial Number 036483XG
Owned outboard since new, lightly used, no previous problems, but due to illness, not run for about 8 months.
Drained tank, added fresh fuel, started on choke first pull, and then run happily at idle with good flow of cooling water. However, as soon as throttle opened, the engine would die, but again would run happily at idle. Found similar problems on this site and I have:-
Again, started first time, run problem free at idle, but died as soon as engine revs increased. Re-did all the above, but still same problem. Engine will run constantly at idle with no problem, but as soon as revs increase.......dies!
I noticed in a thread posted 12-2-2014 on the same subject mentions "(I suspect your correct model is MFS3.5A) There is a long fuel filter screen integral with the fuel cock (hidden inside the fuel line from the tank). Has that been inspected?"
I must admit this is news to me, as the spares parts catalog describes the fuel tank to fuel tap hose simply as "fuel hose and spiral tube." No mention of an inline filter.
Any assistance and advice would be most welcome and appreciated.
- Cleaned fuel tank
- Checked fuel line for blockages
- Taken apart carb, soaked carb bowl and all removable parts in carb cleaner for over 24 hours
- Afterwards blasted all parts through with carb cleaner and then air
- Float appears to be working normally
- Fitted brand new spark plug
