Transom height
L
lancestapp
Guest
Most small and medium outboar
Most small and medium outboards are called 15 or 20 inch. But many boats have 17 or 21 inch transoms. Why do some boats (aluminum in my case) have an extra inch or two of height on the transom?
" Lance.... I've often won
" Lance.... I've often wondered about that myself, and obviously I don't have the answer. Perhaps someone will jump in here and enlighten both of us.
Joe (30+ Years With OMC) "
My guess would be greater tra
My guess would be greater transom height=greater safety in big (rough)water.
" My starcraft chieftan (a
" My starcraft chieftan (aluminum as mentioned above) has one of those nice 21 1/2 inch transoms, a 20 inch shaft works fine, but it's bottomed out.. the engine tends to see a little more water than I'd like.
A solution for it though is to go with a motor mount (or jacking plate) in between the outboard and transom, then a 20 or 25 inch shaft can be retro-fit. "
thanks for the reply. Lance
