hey guys,
didn't hear from anyone on the 270t lift problem- so I isolated and caped off the hydrolic line to the trim piston at tank fitting manifold . the hose fitting was leaking under the pds housing- would have to pull engine and pds housing to get to the hydrolic fitting to replace line-- bad Volvo design! no wonder they discontinued the 270t model! ----- huge problem -- did not need the trim piston on my 27ft boat- i have to have lower unit all the way down to get the boat on plane and carry 1500 lbs live load without bobbing in the waves if I used the trim piston any way- useless---the straight up and down lift is all I need.
question-- since I capped off the lower trim piston hose at the tank manifold- will the hydrolic pressure blow the orings in the normal up and down lift cycle of the lower unit? your thoughts and suggestions please
thanks,
tmcboat
thanks,
tmcboat
