Upgrade 8 hp Johnson
nivek
"I have a 2002 8 hp Johnson wi
"I have a 2002 8 hp Johnson with very few hours on a 14 foot aluminum Starcraft. The boat is obviously underpowered, especially when there in any kind of load in it. I have heard that the only difference between the 8 hp and the 15 hp in that series of motors was the carb., and that a 8 can be converted to at 15 just by switching carbs. Any truth to this?"
"I cannot see an 8hp listed fo
"I cannot see an 8hp listed for 2002. The 2001 8hp I found was a two stroke while the 2003 4 stroke does not have the same cylinder block so is different,
The 2002 9.9 has the same block as the 15hp so you might be in with a sporting chance with upgrading a 9.9.
i suggest you compare part numbers for the engines concerned at http://epc.brp.com/default.aspx?brands=ej&lang=e
or http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
I fear you may have been given duff info."
