thanks for the diagram. I changed the head gaskets and got to the hoses when putting back together and could not remember the correct routing of the hoses. I did take pictures but some are hard to trace down especially the ones that go behind the intake manifold pipes. I have the water lines coming from the vst tank hooked up and the top vent tube from the vst tank ran to the top. One of my questions is the vacuum tank on the vst tank has two lines that I think run to the top behind the pipes. Which one goes to the white air bypass valve mounted at the top between the heads. Any help would be appreciated, getting frustrated, just dont want to hook up incorrectly. Thanks
