troym
Advanced Contributor
5.7L reman long block. Just had the heads done, and have it back together.
Cold compression test on all cylinders good enough (150 was the lowest, 165 the highest). Looks like I'm back to having 8 functional cylinders again. Will recheck compression and do a vacuum test after I have it running.
Getting ready to run it for the first time since completing all the work.
Merc manual gives two procedures for adjusting the valve rockers:
Engine stopped, easy enough and done, but last sentance in the section states "no further adjustment necessary."
Next section in the book is "Valve Adjustment, Engine Running".
...perfect example of why engineers should not write books.
So is no further adjustment necessary after completing the Engine Stopped adjustment, or do I readjust the valves after I have the engine running and warmed up?
