Verado DTS 236 fault
Michael778
Verado 150 DTS — Fault 236 Emergency Stop with lanyard circuit showing RUN (8.5 V)
Engine: Mercury Verado 150, DTS / SmartCraft. Single engine.
Symptom: key ON shows Emergency stop activated / Fault 236. Cranking gives 5 short beeps. Engine will not start. Message does not clear after key cycles.
What I have already checked:
• Type A kill circuit (black and black/yellow). Lanyard switch itself is good: RUN = 8.5 V on black/yellow, OFF = 0 V.
• Same 8.56 V on black/yellow at both sides of the disconnected 14-pin (boat half and engine half). Not shorted to ground at the plug.
• Continuity OK: ECU → 14-pin → lanyard.
• Replaced the ignition switch. No change.
• 5 A clean-power fuse at the battery is good.
• Battery isolator OFF, key ON — DTS still wakes. Clean power appears to be on the battery side of the isolator, so the helm modules never fully power down.
• Disconnecting the battery negative for a long reset does not clear 236.
So the analog stop wire looks like RUN, but the system still reports 236 and blocks start. I am treating this as a DTS / command-module / CAN issue, not a bad lanyard.
Questions for anyone who has seen this on a 4-cyl Verado:
1. With 8.5 V on black/yellow, can 236 still be set by the helm CCM over CAN X?
2. Has relocating clean power after the battery switch plus a hard power-down cleared a sticky 236 for you?
3. Worth checking CAN X (yellow/brown) for ~60 Ω and a live 2.5 V / 3.5–1.5 V waveform before replacing the command module?
4. On CDS, how do you tell whether 236 was set by the CCM or the PCM?
Any help will be
Verado's need strong power, do you have a AGM battery attached and what voltage is measured at rest and while cranking?
My V8 Verado service manual states 9.5V minimum and should be higher is needed on the stop circuit, also the lanyard switch is normally open and grounds when activated
