Volvo 270 chugs in forward not in reverse
logan44
When I am in forward gear, the motor will rev to about 1200-1400 rpm, then it will chug and drop to about 900 rpm. Could this be because of the red shifting cable? T"
"Im going to go with a fuel ca
"Im going to go with a fuel carb problem. When was the last time you had the carbs cleaned? I had similar problem with my aq130c. Now since I rebuilt the carbs, she runs great. There not hard to take apart and inspect. Try that first. Its easy and cheap."
"no the carbs dont do that.Che
"no the carbs dont do that.Check your Idle. This has a big effect on changing into gear. I had a big problem with clunking when I change gears. Since I rebuilt my carbs and reset my idle to 900 rpms, its virtually gone. I still have a small little clunk when I go into reverse, which I will have to check out. but Im happy. Plus its the least expensive way to start researching the problem. If that dosent, keep us posted on what is happening."
""There is a real simple t
""There is a real simple thing that should be checked first...especially if the drive was recently put back on the boat.
Regardless of prop rotation the proper "direction" for the shift cable is to push outward from its sheath in order to engage "forward"... There is a clamping plate on the front of the drive at the point where the cable enters the drive itself. If this is missing, or if the screws are loose, then shifting into forward will become rather problematic.""
"I agree with John. Good place
"I agree with John. Good place to start.
If you can keep a nice, clean, steady idle speed of 650/700 rpm, it helps with shifting and the clunk that you hear from the reverse latch/lock down unit.
Any 270/280 drive is going to do this if the rpm is too high.
You may also want to look into your ignition system. Not only the contacts and dwell, but the advancing unit as well. Time for BASE, and always check total advance."
Robert.
Im missing that
Robert.
Im missing that plastic insert at the point the cable enters the drive. Everything else is there. Do they sell that piece?
"Oooooouuuuh...... El Ricardo
"Oooooouuuuh...... El Ricardo is on the spot here! LOL
I am not familiar with a plastic piece if this is for one of the AQ series drives! This is an AQ series drive, correct?
The shift cable should come into the Intermediate housing and held only by the SS clamping plate for the 33 C style cable.
Can you post an image of this?
"Oops, "El Ricardo" di
"Oops, "El Ricardo" did beat me this time...
"El Pescador, I have a confess
"El Pescador, I have a confession! I am not actually Spanish.
Ricardo has been a High School nick name of mine since the 60's.
I'm a Swedish, Danish "Richard" with a little Irish in me.
I have lots of these 270/280 style single cable clamps if anyone needs one. Shoot an email.
"The design of the Volvo clutc
"The design of the Volvo clutch is such that it "servos" into full lockup, i.e., as the motor shaft turns, the clutch more fully engages. This accomplishes two things: It makes sure that the clutch is really locked up tight at high HP levels but it also contributes to a soft initial engage.
HOWEVER... If the shift mechanism is improperly adjusted and/or there is slop in the mechanism, then you could get the following scenario...
You shift into forward but due to slop or mis adjustment (or a missing/loose cable lock plate)the clutch/transmission does not initially engage fully and there is poor contact between the mating surfaces of the clutch.
Prop begins to spin but transmission is slipping and the engine is not being totally loaded down by the prop load and the engine revs up.
Clutch then servos into full lock position
Full prop load appears on engine
Revs drop.
Now it could also be a carb/ignition issue as well, however the shift adjustment procedure is something that should be done on a Volvo anytime the drive is removed... Also it should be checked every couple of years anyway.
It could also be contaminated/improper oil in the drive unit."
"I'm having my morning cof
"I'm having my morning coffee and just thinking out loud here. Not necessarily disagreeing with anyone!
I agree fully regarding the centering and adjusting of the shift unit, shift cable and shift mechanism and linkage..... this is easy to do.
I always start with cable adjustment for full travel each way..... etc, and conclude with the "centering" the Eccentric Cylinder and all linkage for a True Eccentric Cylinder Neutral setting.
Only after rod/barrel adjustments, should cable barrel fittings, linkage rods and cotter pins be re-installed!
Robert, your first paragraph is a perfect explanation...... They truly do offer a smooth transition.
I'll offer a slightly different twist to the understanding of the Sliding Sleeve and Gear Cup engagement, if you will bare with me here.
I agree with Robert re; contaminated/improper oil in the drive unit. This can cause both slippage and glazing of the sleeve/cup in some cases. I think that what he describes is one of those cases! IMO.
I've experienced a Sleeve/Cup "non-engagement" due to the above AND due to metallic residue on either the cup or the brass sleeve. This normally prevents any full engagement as the particles prevent the surface contact friction that is necessary to pull the two parts together!
It has also been my experience that if a sleeve/cup do make initial contact (friction), that "Full Engagement" follows. It appears to be the nature of the Sliding Sleeve/Conical Cup style engagement!
I'll use Robert's analogy; "that it "servos" into full lockup"..... with the rotating "Gear Cup" pulling the Spiral Splined Sliding Sleeve into itself (the cup)!
Much the same as a spiral "Easy-Out" bit does as it screws itself into a center-drilled broken bolt! The more force/friction..... the more it locks up, and they eventually rotate as one!
Bottom line for me..... I just don't see how a cone clutch scenario could be engaging and disengaging on it's own if all is good within the transmission unit.
If you have the initial cup/sleeve friction and RPM/Torque......... you've got the lock up (again, baring no other contamination issues).
I'd also look to some other possibilities if this sounds reasonable to you."
"My initial problem with my Vo
"My initial problem with my Volvo when I first got it, was when putting it into any gear I would here a clunk. I was at a 1000rpm idle. On the water, I would open the throttle and the RPMS drop and I would chug along or the engine would die. Eventually, My engine would catch up, but there was a serious performance problem and a backfiring motor that followed. I would say I got up to 10mph at full throttle. When I cleaned the carbs, one of them was corroded with white crap all through it. thats the only reason I say start there. your problem sounds alot like mine."
"Ok, i like how much feedback
"Ok, i like how much feedback i'm getting guys! That's awesome! Thanks!
Anyway, from what you are saying, what would I start with? I'm volvo ignorant for the most part. How would I adjust everything, and what do you mean by full engagement?
I guess i need some serious walkthroughs! Sorry about all of the questions, i just really want to get on the lake! The boat is sweet, except for this!"
"One of the big differences be
"One of the big differences between VOLVO and most Merc I/Os is the clutch design. MERCs use what is called a "dog clutch", while Volvos use a "cone clutch". A MERC clutch is either totally disengaged or totally disengaged, i.e., the prop turns at engine speed or it does not turn at all. This transition is so abrupt and harsh on a MERC that they have a switch on the shift mechanism that temporarily stalls the engine out.
Volvos on the other hand go from disengaged to engaged in a more gradual basis, typically during less than one revolution of the engine shaft, but in a somewhat gradual basis. Mercs can take several engine revolutions to engage, however, during that time, things go bang...bang...bang (actually clunk..clunk...clunk)
The single lever shift controls are designed so that during the first 45 degrees of lever movement the shift cable moves, but the throttle cable is stationary. If things are not adjusted properly or if there is slop, the shift cable won't move the shift lever fully when it gets to the end of its movement and then the throttle opens. The design of the Volvo shifter is such that even if the shift lever isn't fully in the engaged position, the cone clutch will literally get "sucked" into full engagement anyway, but not before the engine revs up.
NOW... there is some confusion in my mind as to your problem... so is it:
a) You shift into forward and the engine revs increase and then drop AS IT IS SHIFTING INTO FORWARD...
--or--
b) You shift into forward, the shift occurs but as you open the throttle, the engine bogs down.
If you can't tell easily. There is a way to tell assuming... you have a helper and the water is relatively clear.
Have the helper practice shifting into forward in a slow consistent manner. Then you go to the stern of the boat HANG ON... and look over the stern at the prop. When your helper shifts watch the prop. If the engine revs up as the prop starts to spin, then you have "a". If the prop spins and then the engine revs up and then slows... it's "b".
If its "a", then you have a shifter/transmission problem. If its "b", it's either a carb or an ignition timing problem.
Go to:
http://thestraycat.net/files/Volvo Penta Workshop Manual.pdf
and download the shop manual... the adjustment procedure for the 27o and the 280 etc are the same..."
"Ok. I'm thinking it is an
"Ok. I'm thinking it is an "b" problem. I have had the "helper" and we agreed it was closer to the "b" problem.
But, "b" is a little off. The boat will engage, and as we give it a throttle, the boat revs up, we move, but then it clunks, chugs and the prosses starts again.
So, what do you guys say? We may have those cables a little out of whack?
Second, I'm still trying to picture the cone clutch. I have had dirtbikes with a slipper clutck, where the more throttle is given, the more "hook up" is given. Is this close?
Thanks,
Logan"
"It's quite different than
"It's quite different than what you describe for the dirt bike. There is nothing Centrifugal about the cone clutch. And there is nothing about it that is even close to Dog Clutch type engagement!
Go to this image.....
http://www.dougrussell.com/partscatalog/images/omcvolvo/ACF171.gif"
SEQ # 45 is the conical shaped brass sliding sleeve (brass on your drive).
It is married "to", and slides "on" the vertical spiral splined shaft (SEQ # 44).
The sleeve engages into the continuously rotating gear "cup" of gear set (SEQ # 11) when the eccentric cylinder (SEQ # 56) raises or lowers it via the shift shoe (SEQ #57).
There is no tooth type engagement..... all gears are continuously meshed and are spinning when the engine is running.
Only when the conical sliding sleeve contacts one of the "cups" is friction initiated, and then engagement starts to occur.
(this is what the conical shape of both cup/sliding sleeve do to one another while the sleeve is on a spiral splined shaft)
The friction and the resistance of the spiral splines continue to pull the two together until we have "lock-up" or "engagement"...... In other words, a 1:1 rotation of all; gear/cup/sliding sleeve/vertical shaft!
The result is the obvious rotation of the upper and lower unit vertical shafts!
Wella..... prop motion!
This is a crude alternate explanation:
Think of an "Easy-Out" bolt extractor being used in a center drilled broken bolt!
As the Easy-Out pulls itself into the bolt..... it eventually locks up with the bolt ....., and if all goes well, the bolt now spins one-to-one with the easy-out.
The rotating force of the Volvo cone clutch is actually the reverse of this!
It is the rotating gear cup that pulls the sliding sleeve into itself in a similar fashion.
Hey... I said it was crude! LOL
I still think that you have an engine problem, not a drive issue. Just my opinion.
"What a 'funny' discus
"What a 'funny' discussion.
The problem should not be that difficult to isolate, engine or drive.
First be sure that Your drive shifts fully.
One of the key parts often forgotten is the screw #59 and shims #60. If cone and fork is won and too many shims (60), the cone will not get fully in contact with the gear cones when shifting. This might leave it slipping until more torque is applied and the cone manage to break the oil-film and lock.
Second 'problem' might be that the clearing under nut #53 gets too big. This may not be fixed by just changing the nut to a thicker one, but most often by changing wear ring #51 most of the problem will be corrected.
Furthermore slippage or 'delayed connection' might occur if the cones in the gears have been polished. A careful rubbing with wet-paper 1000 or using valve grind paste may prolong the life and 'solve' some problem.
Bottom line: Just rip the top of the drive off and take it apart. No big deal, just have a decent manual at hand.
To get an idea if what mentioned above is the problem, borrow a 'over sized' prop (23"pitch or whatever'. That will increase the shifting torque in idle to a point where the drive should have no problem in engaging fully at lowest rpm. Then slowly increase rpm - and hopefully the problem is found. If still there -You have an engine problem!!!"
"Morten, yes..... it is funny
"Morten, yes..... it is funny in the respect that the P of O (process of elimination) is apparently not being given enough thought here!
I too think that it is not that difficult to determine whether it's an engine or drive problem.
I do like the idea of trying an over-sized prop if this were to be a larger diameter prop AND following a full engine tune-up including a check to see if the ignition is advancing as it should! (too many set BASE only, and forget about TAT)
It seems like that may shed some light here and at least head him in the direction of eliminating this as a cause.
And I also agree.... inspecting and/or replacing a worn or expanded brass split ring keeper is a must when over-hauling one of these, but I doubt seriously if this is a cause for any slippage.
I've been working on and repairing these for quite a few years..... I've seen only a hand full that actually slip after initial engagement!
It is more often due to oil contamination or light debris (as I believe I mentioned earlier).
If I did not mention this, it would be small brass or steel debris that would have lodged themselves into the brass sliding sleeve conical surface. This can lead to the glazing that can cause a problem.
As for ripping the top off and accessing the cups/sliding sleeve for "de-glazing"........ Logan needs to know that the clamping collar, bearing box and drive gear must be removed in order for either of the two "driven gears" to come out of the gear case.
That can be a challenge if there is any real corrosion around the clamping collar bolts.
This work may be better performed by someone who is trained in this area, IMO."
Note my comment: have a decent
Note my comment: have a decent manual at hand!!
Perhaps I'm a bit to 'experienced' but the Volvo upper units are quite easy to 'operate' and fix as long as no bearing/gear changes does not get into the picture!
I guess LM will be back.
"Ok, went back to the lake tod
"Ok, went back to the lake today. Maybe more details can pin point it. What would it mean if it only happens in the water. I mean we pulleed the boat out and hooked up water on it, I could rev in gear and nothing.No clunks, just smooth running?"
"Unfortunately, all that would
"Unfortunately, all that would indicate is that you now have no loads on anything..... Engine or Drive!
You've got the right idea of using the P of O, you just need to complete that by checking everything.... starting with a full and complete engine tune up.
I mean fuel system, fuel filter, carburetor, ignition, ignition timing for BASE as well as TAT (total advance timing).
See your OEM specs for this!
All of these will make a big difference if this is engine related.
Then move on to the drive..... Prop tune, dirty hull, dirty drive, oil in the drive, and so on.
You will not be able to simulate any of this problem out of the water, IMO.
"Ah. Yeah we have started on t
"Ah. Yeah we have started on that. We have dropped oil in the enginge and drive, new plugs and wires, dist. cap, greased everything in the boat that could be, now its time for bellows. After looking closely, one is completely cracked, which most likely means new ujoints and probably bearings and races? That means removing the outdrive correct? And while that's off I might as well look deeper into the engine/drive and replace other parts. Haha. Man, I only paid 300 for the boat, trailer, and it ran at least.. I still don't think i did that bad."
"Logan, If you have a torn dri
"Logan, If you have a torn drive bellows, and have had severe water intrusion in this drive, it may be locking up on you now....... Had I known this, I may have touched on this earlier.
Are you able to send me a few pictures of the drive? In 1972, this may have been the 250 drive. I have three of these that will be for sale soon. They are becoming a little more difficult to find in good condition.
I aslo provide a repair service for those who need out-of-area repair work done. They ship/I repair/I ship back. These fit in a USPS flat rate box. About $14 each way... cheap!
Go to my profile, and I think you can find an email link. Use the subject line so I don't accidentally dump it.
Rick"
"So what does that mean i need
"So what does that mean i need to do. We looked at them, but that was when i got the boat, and we must have not looked close enough. This makes me a little sick now. How much damage is done? Or what do I expect? Ricardo, what would i send you? The bellows? How would they be fixed uf so?"
"Like said...... [b]Go to my p
"Like said...... Go to my profile and find my email link. Use the subject line so I don't accidentally delete it.
If you are in the states, we could have a phone discussion.
Mean time, I'd be removing the transmission and taking a look to see what, if any, type of damage has occurred. If not too late, I'd also be draining the drive oil from this.
