im swapping out a 280 leg/shield for a 270 leg/shield.
the pds bearings were fried in the bell housing
did an exhaust pipe delete and wound up taking the flywheel/bell housing out the hole in the transom, instead of pulling the motor, by zip cutting the lower 2 corners of the housing
between the housing and shield theres a rubber ring
then you have that mounting ring with 6 bolts and another rubber ring
does anyone know the torque specs on those 6 bolts?
also the shield has 6 bolts through the transom, anyone know the torque specs on those 6 bolts?
