Recently changed my 24' Walkaround from a Volvo Penta 1.6 single prop to a DuoProp. I changed just the lower to a DP 1.78 Gear Ratio. The specs are as follows....
Stock Numbers:
Single Prop SX 1.6-
WOT---4500 RPMs 36MPH.
14.5 x 19p SS Prop
The Boat was always a disaster with Top speed and seemed to never want to plane correctly. I built a high horsepower 302 Ford to replace the 180hp anchor that was in the boat from stock, Played with countless props and could never get the boat to a normal speed without tons of slip or over working the engine. So Fast Forward to Present.....
SX-M 1.6 Upper (stock)
DP-S 1.78 Lower
F3 Volvo Props.
WOT -- 4000rpms 37Mph
The boat is much better overall in acceleration and responsiveness. The Boat rides 1000% better and can easily raise the Bow up with slight trimming as when the single prop drive was on, it would just plow thru the water.
Ive read on another forum that the Ratio is calculated between the upper and the lower? Some say its just the Lower, some say just the Upper? A math equation on another forum states that i have actually went down to a 1.51 Ratio?!? Here is the Equation.
Upper (SX and DP-S):
3857007 BRP HSG AY,GEAR 22:23 (1.43, 1.51, 1.60, 1.66, 1.68, 1.78, 1.95)
3857010 BRP HSG AY,GEAR 21:26 (1.79, 1.89, 1.97, 2.18, 2.32)
Lower (SX):
3855692 BRP G'CASE AY,SX 19:26 (1.43)
3855693 BRP G'CASE AY,SX 18:26 (1.51 and 1.79)
3855694 BRP G'CASE AY,SX 17:26 (1.60 and 1.89)
3855695 BRP G'CASE AY,SX 17:27 (1.66 and 1.97)
3855696 BRP G'CASE AY,SX 17:30 (2.18 only )
To get the final ratio value, multiply both ratios together. So for my 1.79 I have 21:26 and 18:26. So the final ratio is (26*26)/(21*18) = 1.79
I have a chance to get a 2.38 Upper locally and i would like to possibly explore putting this on and see if it helps. With that calulation and providing it mates up, it would bring me to 1.79 if the equation is correct.
Any Clarification would be helpful!
Stock Numbers:
Single Prop SX 1.6-
14.5 x 19p SS Prop
DP-S 1.78 Lower
F3 Volvo Props.
Lower (SX):
