RicardoMarine
Gold Medal Contributor
First, I'll share this with you.Question: any curve balls to be concerned about when removing the outdrive?
I remove the transmission ONLY for bellows, bearing cross replacement, water neck fitting and/or shift cable replacement...... and/or any re-sealing of the transmission!
I see little need to remove an entire drive UNLESS we are doing hinge pin bushing replacement, Reverse Latch bearing sleeve work, Pivot Tube work, etc.
There is just no need to remove an entire drive, IMO.
If you DO remove an entire drive, I'll caution you when it comes to removing the Main Suspension Fork hinge pins. These pins themselves are very soft compared to carbon steel.
Since these will very likely be somewhat corroded and stubborn, I always heat the aluminum pin bosses on the transom shield before attempting to remove both the keeper bolts, and the hinge pins. (a small Mapp Gas or Propane Gas torch works well)
This expands the aluminum some, and helps break up any corrosion!
You will NOT harm the aluminum with Mapp or Propane!
Like said, the issue is that these pins themselves are soft.
If we drive on them with any tool harder than an Italian bread stick, we risk expanding the pins, and then we have a real mess!
So......, drive on these pins ONLY after heating the bosses......, and with either brass or aluminum ONLY, and of an appropriate diameter tool, and they should come out easily!
Again, most anything that you need to do to the transmission, and/or lower unit, can be done with the Intermediate housing still attached to the transom shield.
Both Transmission and Lower Unit must be removed anyway for replacement of the O-rings!
Just my opinion. Your call!
