i got the 510 kit that you have to drill and tap the prop shaft
thrust washer fits the shaft at 28.3mm id
the plastic housing bushing that snaps in the hub is measuring 32mm id, the id is too large by 3mm
is that normal?
i was thinking i would 3d print a carbon fiber bushing to replace what they sent me
i still have to print that bushing because i snapped a tap in the shaft and am using the hub kit as a drilling guide for a 6mm diamond hole saw to drill out the broken 5/16 tap. i wont print the part in carbon fiber if theres supposed to be a 3mm gap between the hub and shaft
is that normal?
