Hi all,
Johnson 1975 6 hp.
Changed out impellor everything went smooth.
I now have some water drips coming out at gear shift shaft. Just easy drips now spray. This is the first time I run the engine this season by way of a barrel test. The motor runs just fine. The water pump is doing its job. I do not recall the water the drips last season. I don't know. Water tube leaking? Power head gasket gone bad? Symptom of something else? Your inputs would be most appreciated at this time.
Johnson 1975 6 hp.
