Woodybelle
Have weak spark on all (6) cylinders / no start condition. Motor will fire (not run) with starter fluid. Possible fuel delivery issues have been eliminated. Rebuilt carbs have been synchronized and timing set with OMC analyzer. New parts include: ignition coils, wires, power pack, timing sensor, ignition switch, etc. The (new) timing sensor has been tested (good) using the OMC analyzer. I assume that the timing sensor test would have revealed an issue with the sensor coil????
After reviewing OMC manual (and two others), I saw no mention of troubleshooting or diagnosis for WEAK spark. Abundant direction offered for every other combination of spark / no spark. I doubt the diagnosis for “weak spark” is the same as for “no spark,” since “stop circuit” and “shift switch” should be out of the equation. Besides, I have tested both of those circuits. Regardless, I believe my testing progression should have revealed the current issues/s.
I tested stator (still on the motor). Impedance (orange stator wire to orange/black stator wire) measured 54 ohms (good). Cranking voltage was present indicating grounding / bad stator….according the OMC service manual.
Bottom line: A new CDI stator is scheduled for delivery next week. Hopefully, the solution will be with the stator replacement.
Given the delay in getting parts, I’d like to know if any other parts should be considered, tested, and ordered. Am I on the correct path? Is there any other issues I should be considering?
Forgot to mention: Batteries fully charged.
Thanks in advance for input.
