238 Coastal
95 200hp Johnson Ocean Runner 950hrs -
Well cared for motor was running great till this weekend when it went into SLOW mode. Yes, it is SLOW mode, idles but shakes in gear and low rpm's AND starboard side bank not firing. Was not hammering it all, very easy day of morning trolling and then drift fishing inside. NO alarms. NO nothing, other than water pressure gauge pinned to 0 but still steady stream from tell tale. NO over heat, block as cool as a cucumber and days later still in SLOW mode. I have checked shift interrupter switch, it is still reducing rpm's even in SLOW mode. I have checked temp senors at least for continuity, both good, but worried now because port side temp switch is NO LONGER AVAILABLE. VRO was replaced in July. Impeller replaced in July. Carb's rebuilt in July. Oil level was 2/3 full on a 3 gallon tank.
However, I did find vacuum switch plug not to be in great shape, it is the one that is encased in rubber for some reason. But there were no performance issues from that before, and to be honest, me digging around in there AFTER may have damaged that plug.
So...does SLOW mode cause the lack of water pressure? Or did the water pressure drop cause the SLOW mode?
I can't find anywhere where the vacuum switch would cause this...
Again, I had the Johnson in prime running form at both WOT and idle/trolling (salmon) and ALWAYS running very cool. NO ALARM, though alarm does sound at start up...
Thanks for any and all help!
238Coastal
238Coastal
