What size kicker motor can I get away with?
Cam the RN
I have a 24 foot pontoon with a Johnson 115. I am wanting to get a emergency or "backup" motor to get me off the lake in case the old Johnson quits. Granted, I have done a lot of maintenance on it over the winter. But I am too old to sit out in the sun waiting for help with my grandkids. I am going to buy something that I can throw on one side of the back in the event I have a problem. They have little bolt on brackets to mount a small outboard on. So I'm thinking I could get a small motor and keep it in a locker or box on the front of my boat to take out in this situation.
My question is, what is the smallest size could I get away with? I don't know how powerful they would be at lower HP ranges. The lake I have my boat on is only around 2-3 miles wide. So would a 5hp or 4hp work for that big of boat. I just need something to get me back to my boat slip. 2 stroke or 4 stroke, doesn't matter. My 115 Johnson is a two stroke. Something light would be good too.
I thought about a trolling motor. But I don't want it to be battery dependent, In case that's why my motor doesn't start. I do keep a jump box with me as well.
It would mainly be for engine failure.
Any opinions would be great. And thanks in advance.
Yes, a 4 or 5 HP outboard would get you moving and eventually get you to the dock. The Evinrude 9.9 engines were very simple, they are all over to this day, and were dead nuts reliable. If you can find a good one of those it would serve you well for this purpose. I had a 9.9 that I used on my 19' bass boat for small, HP limit lakes. At WOT it would push the boat about 6MPH. That's quick enough to get you off the lake if needed.
Depends how fast you want or need to get off lake.
I would go to the 15hp. That's pretty much an all around engine. Weighs about the same and it's like a 9.9 on steroids.
One thing to consider when picking / installing a kicker is-----" Will I be able to lower it into the water and start it safely " ----Perhaps need electric start.-----Or can other people start the motor if need arises.
I can still pull start a small motor. But you guys are right. I need to be able to lower it down on the bracket when needed. I don't need to go fast.
I looked online, my lake is only 2 miles from the furthest point to my slip. Around here, a 15hp is pricey. I kinda want to spend around 400-500 max. There are a few around, I just wasn't sure if they'd be able to push my toon back with that little power. Thank you fellas. I'll let you know what i get.
Twin cylinder 4 horsepower 2 stroke Evinrude or Johnson, 1968-1980. All day long, best engines ever made for your application, thousands still around with tons of parts still available.
Do some looking into how high your mount ends up. You may very well need a long shaft motor.
Your lake is not very big, so even at a fast walk speed, you’ll get to safety with a small, (read “light”), motor.
For your application, I would source a little 6hp johnyrude.(is your lake subject to lots of wind? A 2hp only weighs 18lb, but might not be able to overcome a windy lake). Long shaft if required. There are lots of them around, lightweight, easy to find parts.
One further often overlooked item. Pushing a bigger boat, you’ll never get those little motors to spin up to full rpm, UNLESS, you can find a prop meant for sailboats. The 6hp did come in a Saildrive model, finer pitched prop so you could get the full 6hp. Those props are getting harder to find, but a finer pitched prop would make a noticeable difference for your application.
