daltonallen
What is this hose in the middle of pic going vertical and where does it end?
Hi,
Since you didn't supply year and model, I took a guess and came up with an older 9.9 model. Close?
If not, this may not be entirely accurate but here goes:
The hose is the crankcase breather hose. The device it's hooked to up top there is the crankcase breather assembly. See item 5 in the link below
I believe that the hose simply exits out the bottom of the powerhead case to atmosphere.
But, I'm not 100% sure about that because most later models have the crankcase gasses directed into the engine intake via the Inlet air ducting and muffler system. Which, your photo clearly shows isn't present on that model.
However, it could be that the hose is plugged into the intake manifold to re-burn the gasses. I don't know because I have never worked on one.
Hope this helps.
Good luck.
