When centrifugal advance springs get old, do they get stiff and therefor not advance the timing as much as they should or get soft and advance too much /too early (at a lower rpm).
My guess is they get stiff.
This is on a 91 Ford 5.8 L the timing should be 10 Deg BTDC at Idle up to 1000 rpm then increase up to 30 deg total advance at 5000 rpm. It should be about 19 deg total at 2000 rpm. I was getting much less that that at 2000 rpm.
[FONT=Arial, Helvetica, sans-serif]Do I have old stiff springs? [/FONT]
[FONT=Arial, Helvetica, sans-serif]BTW I'm just trying to get back to the OEM advance curve. I'm not trying to change anything. There are a few pretty good posts on here about the dangers of playing around with the advance curves.
[/FONT]Thanks
[/FONT]Thanks
