wet_wonder
"I have a 5 cyl V8 single inbo
"I have a 5 cyl V8 single inboard setup - I believe it's a Mercruiser 302 or the like - and I have white emission smoke at any rpm above 1000.
The temp gauge will hit 180 degrees when I'm at about 1,200 RPMs. As the RPMs increase over 1,200, the temp will keep rising and the white smoke will increase. At 2,500 rpms, the temp will climb to 220, white smoke continuing. Water sputters out the exhaust, along with the white steam. I can't really tell if it is a proper flow, even though all these clues suggest it isn't.
I have a raw water system. So as not to be mistaken, the water taken in from the seacock directly cools the engine before exiting via the risers.
I bought the boat - Trojan Express, 25', 1976 - last year and inherited this condition. This off season I replaced the thermostat and impeller. This season the smoking/over heating continues. Otherwise, the engine and all other systems perform very well. The motor was installed in 2005, and has 280 hours on it.
I figure that there is probably a circulation problems, via a blockage, etc., and that I'll need to take the screen off, the hoses apart, the risers off, and the manifold off to inspect the exhaust system. And will find clogging. And I'll need to clean everything out, and replace some of it, as needed.
That said, I'd be grateful for any insight my fellow boaters may have before beginning this project, which will sideline the boat for a couple of weeks.
Thanks very much,
Wet Wonder"
Thanks very much,
Wet Wonder"
