Austintatious
So yesterday I decided to open up both 454XL's for a bit. WOT for Port engine was 4200, 3900 for Starboard.
After 5 minutes of WOT my starboard engine starting throwing a lot of white steam/smoke out of the exhaust. I think I noticed a faint burnt rubber smell at first. The engine didn't overheat (175), seemed to be running smoothly, has started fine since then, etc.
I opened up the engine compartment and the exhaust hoses on this engine were very hot (couldn't keep my hand on them) compared to the exhaust hoses on the port engine. I also noticed some white steam/smoke in the engine compartment but couldn't tell where it was coming from. Seemed to be wisps from the exhaust hose area.
The white steam/smoke slowly went away as I made it back to the dock on both engines at around 2000rpm. It was getting dark and I only had a chance to check the oil and it appeared to be fine, not frothy or creamy colored.
I suspect I have insufficient fresh water flow and the exhaust hose(s) were burning up? This doesn't seem to fit the scenario of a blown head gasket but I'm not an expert.
