Repsolboy1
Hi,
I bought this boat this year with a 2004 Mercruiser 350 mag mpi horizon package and a Bravo 2 out drive. On previous boats, I normally ran anti freeze through the outdrive but this boat has a 'coolant' and a hull thru raw water pick up hose with a lever. When winterizing, will it be enough if I put ear muffs to the out drive and run the engine or should i use the hull thru pick up hose for anti freeze?
