Wiring Diagram for 55 Evinrude 1968 Outboard
HEB
I have to install a motor wiring harness for a Mod 55873R 55hp Evinrude Ser#C577609 55
I need colour coded diagram.
Thanks HEB
was replacing starter switch on 1969 Evinrude 55 and had an incident where an accessory positive line was tapped the solenoid connector on the starter switch and when you turn the key to "ON" position but not the "Start" mode, the starter engages immediately. Have replaced the switch twice now and still the same problem. I disconnected the Ignition line to the switch and get nothing. checked wires at the motor and all seem good. Not sure what the issue i
