Yamaha 4 Stroke 6hp Outboard Issues!
superflychris
So I went to go sailing for the first time this year, had my outboard down below for six months lying on its side.
When I went to start it, the pull cord stopped as soon as the fly wheel tried to engage. Kept trying and it's loosened a bit, but still super stiff.
I took the top off and can just about turn the fly wheel manually, but very stiff.
I also took the spark plug out and tried pulling. But no difference.
It worked perfectly before we put it away for the season, any ideas??
Here is a video showing the issue:
Checked the oil level.----Best to store these motor upright.----If you store them the wrong way .
oil can fill the cylinder and oil does not compress.
Hi there - thanks for the replies. I tried sea foam via the plug, over a number of days. Might have loosened up a bit, but not much.
Changed the oil.
Nothing else seems to be working. :(
Is it the same when you try rotating the prop by hand (clockwise)?
I'm working on an old Mercury 45 and flywheel wouldn't even budge, so I dropped the lower unit and the pull start freed up. So now it's on to the gearcase...
