Tony Outboard
Hi All
I have the above engine, have cleaned the carb numerous times, checked the plug, compression and valve clearances etc but for the life of me can't get it to idle properly and it bogs down a little when I open the throttle.
It wasn't me - honest, but a previous owner has removed the plug and likely fiddled with the screw-air adjusting, does anyone know the default factory setting for this screw and if it had been fiddled with, could that cause the engine to run rich (which is what it's doing), failing that, any ideas anyone?
